Cutting Prims
   1374   6   2
Can somebody teach me how to cut the lines like this in VEX?
Hey OWZONE,
I guess there is a complex VEX solution. But Im a simple man so here is a setup using a loop. It works for straight cuts only atm. If you need angled cuts you need to calculate the orientation of each edge. A bit more complicated but doable.
Cheers
CYTE
Cut.hip (85.3 KB)
thank you so much for your method, CYTE!
Edited by OWZONE - Dec. 21, 2023 20:51:53
Hi
I tried a more-procedural way. I guess it might be faster.
Edited by abingabingaaa - Dec. 25, 2023 05:04:22
abingabingaaa
Hi
Interesting... I didn't know about PolyScalpel. Looks like an exotic node. Would you mind sharing the hip file or the parameters on PolyScalpel?
Edited by kodra - Dec. 25, 2023 21:20:34
PolyScapel is really good to solve multiple kind of cutting situations.
Cut (1).hip (169.9 KB)
abingabingaaa
Thanks for sharing the method, great one ☺️
