I am trying to use the clone control panel but it is giving me an error:
MESSAGE SEND ERROR(clone1) ws://127.0.0.1:36871/clone Msg='""' Error='"Broken pipe"'
Any tips?
Clone control panel error
1525 8 1- mzigaib
- 978 posts
- jason_iversen
- 12670 posts
Could you post your OS / license type / version numbers / etc?
Is Karma able to start up okay otherwise? I remember seeing issues with Apprentice limit-resolution and such.
- jsmack
- 8043 posts
- mzigaib
- 978 posts
jason_iversen
-Fedora 39
-Apprentice
-Build 547
I did try both Karma XPU and CPU.
And yes Karma is working normally in CPU and XPU on normal renders.
- mzigaib
- 978 posts
- mzigaib
- 978 posts
- mzigaib
- 978 posts
- mtucker
- 4525 posts
I'm sorry, I have not seen this myself. And nobody else is chiming in here so I assume it's not a terribly common problem. That's going to make it tough to track down...
By the IP address I'm assuming this is a local clone you are creating? Have you got any unusual plugins running in Houdini, or is this basically a vanilla installation?
- mzigaib
- 978 posts
I am using Labs, qlib and MOPs nothing too unusual.
The thing is that it seems I need to point exactly the node I am rendering then it works but if I just point to the stage sometimes it works sometimes it does not but it is hard to pinpoint exactly what the problem is when the log jus says "Operatin Canceled".
I will keep my eyes to see if I got any more unusual behavior.
Thanks for the feedback.
