H20 usd camera not updated when render setting changed.
   937   2   0
Hi Im on H20.0.547 and found that if I ref/sublayer a usd camera, then change resolution in render setting. The camera crop will not update in viewport. I've checked the same usd file in H19.5 and it updated correctly. It will render to disk and mplay correctly, but this make viewport ipr useless.
My current workaround is to use Obj Alembic Archive and set the resolution there first. Then use scene import.
Is there any change in how we edit the camera loaded from USD files or this is a known bug?
creepmaster
works fine here with 20.0.555
I don't have a usd file to sublayer, but creating a camera node does effectively the same thing.
jsmack
creepmaster
Creating a camera node works fine in this case, only explicit ones have this problem (including alembic sublayer).
On further investigation, I found that it has something to do with htoa (latest version for 20.0.547) and only Windows build.
My home machine is Linux Mint with same Hou and Htoa version, and doesn't have this problem.
Disabled the plugin and the problem went away. Now I have to find other workarounds.
Edited by creepmaster - Dec. 30, 2023 05:16:16
