Hi and have a good new year,
I have objects on OBJ level under NULLs, changing the view to my needs.
Going into SOP level, I like to have the same perspective as in OBJ level, but the objects always are lost because they don't recognize the NULLs (That is logic ;o)
Any ideas?
Detlef
changing viewport between OBJ and SOP level
1206 6 1- winkel
- 218 posts
- CYTE
- 709 posts
- bollili
- 214 posts
- winkel
- 218 posts
- winkel
- 218 posts
CYTE
Hey Detlef,
set this little icon to show or ghost other objects. This way you stay in OBJ transformation.
If it is set to hide other objects you dive inside the local space of the selected OBJ node.
Cheers
CYTE
a good idea but I have a lot of Objects I don't want to see/select in SOP-level.
I have some subnetworks on OBJ Level and inside a hundreds of object... came from CAD
- CYTE
- 709 posts
- winkel
- 218 posts
