Trouble Disabling Automatic Simulation in Houdini – DOP Net
   941   2   0
Display of DOP Net was turned off, but simulation is happening automatically. Is there a way to disable this feature? I don't know what I touched, but even though the DOP Net node is not displayed, simulation is occurring...
Edited by immeen - Jan. 19, 2024 03:32:50
in your screenshot the popnet1 is still a current node (yellow outline)
so as long as your Viewport is set to Show Current Operator it will still cook it, or if you have Geometry Spreadsheet visible, etc
if you want to temporarily disable cooking of DOP networks regardless you can click on the Brain icon to toggle that
FX Supervisor
Method Studios, NY
I ran into the same problem. I didn't select the dop node, but the sop node in front of it. When I played it, it always ran the dop.
I only encountered this issue when using Houdini 20. When I copied the files to other versions such as 19.5 or 20.5, the problem did not occur.I don't know what I changed in version 20, could anyone help me?
