Building and running a plugin from samples/DM/
   1562   1   1
I have built a few samples from samples/SOP/ using the hcustom command.
The build target .so ends up in my $HOME/houdini20.0/dso/ directory.
After launching Houdini, I open Texport and run dsoinfo command. I see the SOP plugins listed as loaded.
So far so good!
Now, if I do the same with plugins from samples/DM/ then I also end up with a .so file in the right directory.
But dsoinfo will not show it as loaded.
Do DM samples require a different approach to building or running compared to the SOP examples?
Thanks.
Platform: Linux RHEL9
Houdini: 20.0.591
Edited by bram_stolk - Jan. 26, 2024 11:36:57
UPDATE: Even though they are not listed, I see that the DM sample plugins do work.
So this is probably just a shortcoming of the dsoinfo utility.
