How to disable display of a selected node in Scene Viewer
   1222   5   1
Seems simple, but struggling to find it.
I want to edit a node's parameters but I only want to see the final downstream result in the Scene Viewer. By default selected nodes are overlaid in the view as wireframe which I don't want to see while I edit their params. I onlt want to focus on the end result.
I know I can pin the parameters pane for that node, but I want to disable its display completely so I don't have to pin it.
Is there a way?
Try this toggle.
Edited by pabcou - Jan. 26, 2024 09:42:27
pabcou
Try this toggle.
OK that does work, thanks. Its not possible on a node-by-node basis I take it?
As far as I know, it isn't.
RT_SD
pabcou
Try this toggle.
if you hit escape in the viewer then the current node won't be displayed anymore. So you can go back and forth as needed with enter or escape.
jsmack
RT_SD
pabcou
Try this toggle.
Ah! Yes it works perfectly. I even know the escape key thing... why did I not try that?!
Edit... I know why, there's 1 more step. You have to hover the mouse over the scene view for escape/enter to work, but then you have to click in the node graph again for the overlay to actually dissapear.
Edited by RT_SD - Jan. 27, 2024 05:03:43
