Using point position to matchmove and align geometry.
   454   0   0
Hi
Before I look to try and make my own implementation, I was wondering if there is a node i may have missed which would do the same thing.
I'm wanting to align geometry based on point position from input 1 and 2 without any scaling, or scaling being optional.
I would specify a point number from Input1 and another from Input 2 to essentially create a pair and i would match several pairs in a multiparm of some sort.
By specifying pairs, the geometry from Input 1 can then be moved into position based on the point pairing.
Similar technique to aligning the scene in matchmove where you pair the 2D tracked point, from your footage, to a location on the mesh.
