HOW can I make hython wait for PDG job to finish ?
   Views 962   Replies 2   Subscribers 0
I have a vellum sim setup I want to run on a given set of FBXs and various frame ranges in batch.
The current HDA runs everything in PDG.
Hython isn't waiting for PDG to finish the task.
Is there a TOP or python command to make the hython python shell wait until PDG is done?
Thanks for helping
I figured this out. you can't call pressButton()
you have to call the function on the PDG node with Block
node.cookOutputWorkItems(block=True, generate_only=False, tops_only=False)
skydancenewmedia
Thank you very much!
You saved my day
