Hello everyone,
I am trying to create an animation where some objects are pushed and dragged by a liquid. I'm not clear on how I should set up the DOP network and how to make the particles interact with the rigid bodies reciprocally. Could you give me some pointers or some links to docs/tutorials?
I searched the net, but I couldn't find this information.
Thank you.
RBD+FLIP
2810 16 1- deremis
- 9 posts
- Enivob
- 2629 posts
Maybe this setup can help.
https://forums.odforce.net/topic/52705-help-with-floating-rbd-objects-on-flip-sim/?do=findComment&comment=240207 [forums.odforce.net]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- deremis
- 9 posts
- tamte
- 8837 posts
- deremis
- 9 posts
Thank you Tamte,
i wasn't clear, the problem is that the pieces are not generic debris, but instances of small objects.
Unfortunately, I cannot provide many details about the scene due to a confidentiality agreement (NDA), but technically it's like having to animate a liquid that moves hundreds of small "Lego" bricks of different shapes and colors.
Something like the image i'm sharing
Thank you
Thank you
- cncverkstad
- 155 posts
- tamte
- 8837 posts
I don't see a reason why wouldn't you be able to use RBD Fractured Object with them, the name may be deceiving but it can be any geo with pieces defined by name attribute, doesn't have to come from fracturing
Alternatively you could also use Vellum to simulate both, liquid and rbd pieces, depending on whether it suits your project
Edited by tamte - Feb. 14, 2024 03:58:16
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- deremis
- 9 posts
cncverkstadThank you, i'll search for it.
combine files and methods from CGworld Japan
tamteHi Tamte,
thank you, didn't know i could use any type of objects with the "RBD Fractured Object".
Could you give more details about this? I would be really grateful to you.
- rafaels
- 700 posts
Hey deremis, you'll be able to find some help here:
https://www.sidefx.com/tutorials/legoize-geometry-and-rbd-simulation/ [www.sidefx.com]
And here for the vellum fluids part:
https://www.sidefx.com/tutorials/h19-vellum-fluids-starter-pack/ [www.sidefx.com]
Toronto - ON
- deremis
- 9 posts
- deremis
- 9 posts
Hi all,
I've been attempting to make RBD objects interact with FLIP fluid by using the RBD Fractured Objects, but unfortunately, I'm unable to get it to work properly.
While the FLIP fluid is colliding with the RBD objects, the RBD objects themselves aren't moving.
Could someone kindly take a moment to review this setup?
Your assistance would be greatly appreciated.
Thank you.
Thank you.
Edited by deremis - Feb. 16, 2024 09:56:44
- tamte
- 8837 posts
deremis
1. your fluid resolution is low relatively to the sizes of the rbd pieces
look at the Collision guide in your flipobject1
so
- set it to at least to 0.01 which would make the grid res 0.02 which would start making some effect
- or use separate collision separation that will capture the resolution of your pieces
- or make your pieces larger
2. your fluid density is 1 while rbd 1000, so the fluid has barely any effect
set your fluid density to default 1000 and rbd can stay or can be more or less depending on if you want it to float or sink
Edited by tamte - Feb. 16, 2024 12:59:07
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- N-G
- 209 posts
tamtederemis
so
Dear Tomas, I have a question. If we use the old RBD Sim for interaction with FLIP, how can we control RBDs like we do with the Geometry Wrangles beside the RBD packed objects?
- tamte
- 8837 posts
N-GIf you use old RBD you are limited to control and workflows that old RBDs have since each piece is a DOP object directly, etc.
Its definitely a workaround just to make FLIP feedback working, and ideally SideFX would find a way to make mutual interaction of all solvers working one e day
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- deremis
- 9 posts
- tamte
- 8837 posts
deremisFLIP Object DOP/Properties/Collision Separation can be enabled and set to smaller (or larger) grid scale than other grids whose grid scale is Particle Separation * Grid Scale
Thank you very much for the precious tips Tomas.
May i ask you more details about this?tamte
therefore you can have lower res FLIP sim, but still have it consider higher resolution collision grid which would see more of your small colliders and can provide feedback to them
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Kareeem
- 64 posts
