Calculate avg position with weight per point
   Views 882   Replies 3   Subscribers 2
I know that to calculate the average position you just need to loop through points add their position together and divide by the amount of points but how can I have a wight per point so it does not have so much influence on the average calculation.
For example I have 3 points and I want to calculate the average position for all of them but I wand point 2 to have 0.5 weight on the influence for this calculation, I hope it makes sense.
I am not very good at math so I need help on this one.
Thanks in advance.
https://vimeo.com/user2163076 [vimeo.com]
multiply each position by its weight, add them together and divide by sum of weights
Edited by tamte - Feb. 28, 2024 15:26:03
Might be simpler ways but here`s one:
In a wrangle:
v@weightedP = v@P * f@weight;
Then use two attribute promotes to calculate the sums of @weightedP and of @weight;
Divide the sum of @weightedP by the sum of @weight to get your average;
Edit: Got tamted.
Edited by Tanto - Feb. 28, 2024 15:33:49
Thanks for the help guys!
