Learning APEX but unable to select control geometry
   1098   2   1
Hi guys I'm watching the APEX master class but I run into problem very quickly
https://www.youtube.com/watch?v=-0KbPtoP5MU [www.youtube.com]
It is said the second autorigcomponent with a configurecontrols parameter will do the job and make the control geometry able to be selected.
But in fact I cannot replicate this step.When I attach the torus to the rigged object I am still unable to select the control geometry
Anything I am missing?
hip file here...
h20_apex_explore.hip (1.5 MB)
Hi there,
you have to set the configure controls to use guides. you will see there is a use guides parameter, set that to 1
Hey,
I just came across this issue. Even though everything was set up correctly I was not able to select the control geo.
What ended up fixing the issue for me was restarting the session. I tried this multiple times and the control geo was only selectable after a restart.
I am not sure what causes the problem though. Maybe someone else knows more about it.
Cheers!
