primpoints() with ends gives vertex count?
   807   2   1
I'm freaking out a little cause vex primpoints() seems to be returning vertex count and not point count when using ends sop on a closed curve:
- Add a default circle SOP
- Append ends, set to unroll with shared points
- Append Wrangle in Points, Prim, or Detail mode
- Add code: printf("%i points\n", len(primpoints(0,0)));
This prints the vertex count for me, NOT the point count (one less) since one is shared with two verts.
The ends sop reports 12 points, 13 verts, 1 prim.
The print gives 13 points.
How am I doing this wrong or misinterpreting things?
EDIT: Just printed the points from primpoints() and it's duplicating point 0 at the end. Still doesn't make sense to me.
Edited by Len - March 5, 2024 19:14:47
Len
primpoints() will return points that the prim vertices are attached to, it will not deduplicate point numbers, so you will essentially get point per vertex
Edited by tamte - March 5, 2024 21:51:09
FX Supervisor
Method Studios, NY
Thanks. That explains it.
