Grouping split UV pieces and rearranging them, possible?
   812   3   0
I want to rearrange the UV of the fractured structure to fill up the available island space. However if I use UV layout all the small pieces will scatter around, is there any way I could re-arrange them as if they are grouped or connected into one UV piece?
You can use a UV edit node. There You can move UV islands like geometry. You can select them by UV connectivity
or by group if you have set them up accordingly.
Cheers
CYTE
thanks, but I was thinking is there a way to do it procedurally?:S
Edited by OWZONE - March 12, 2024 07:02:43
Ah ok, I didn't read carefully enough. In the UV layout node under connectivity, you can specify an Island attribute.
Cheers
CYTE
