Ragdoll with realistic shoulder?
   890   1   1
Hi, is it possible to use ragdoll with realistic shoulder solver?from the pinned ragdoll example this looks great however the shoulder look wrong.
Best regards
Patar
Greetings,
apologies but I am not quite sure what the problem is without seeing it.
What I can say though is that you can absolutely run the ragdoll solver on a skeleton and then use the realistic shoulder to correct any issues that might have appeared. You just have to get the ragdoll solver output skeleton and run it through a VOP where the realistic shoulder is set up. That said, it might be worth diagnosing the ragdoll shoulder issue first.
