Installing redshift for houdini
   2049   1   0
I referenced the other thread on this topic and tried to copy their code exactly and still found no success. I also followed tutorials to a T and still no success.
here is what I have saved as a .json in this filepath: D:\Program Files\Houdini\Houdini 20.0.590\packages
"env" : [
{"REDSHIFT_ROOT":"C:/ProgramData/redshift/Plugins/Houdini/20.0.590"},
{"HOUDINI_PATH" : "${REDSHIFT_ROOT}/Plugins/Houdini/${20.0.590_arm64}"},[quote][/quote]
{"PXR_PLUGINPATH_NAME": "${REDSHIFT_ROOT}/Plugins/Solaris/${20.0.590_arm64}"},
{"PATH" : "${REDSHIFT_ROOT}/bin"}
I don't
think this should matter but I have Houdini installed to my D: drive and Redshift installed to C: , due to the Maxon app not allowing for custom file path installations.
Hi!
Maybe you can try with my .json package, it has less variables compared to the version that you shared. You will only need to update the Houdini build from .625 to .590 based on your version.
Hope works for you,
Cheers!
Redshift.json (338 bytes)
