File pattern - Specific files selection
1653 8 1- papsphilip
- 385 posts
i'd like to use File Pattern TOP to select specific files from a folder, there is no pattern though, no similarities in naming.
Something like a multi parm menu would be super useful. Is there a way to do this with another node or do i have to built it myself?
Maybe File pattern is not the only node that reads files from disk?
- alexwheezy
- 318 posts
Pattern allows wild cards such as ? (match any character), * (match any string of characters), and (match any one of the characters inside the square brackets). For example, *.png matches any file that ends with .png. But I don't think it's going to be flexible.
You can first read all the files from the disc using the *.extension template, and then filter the desired files using Filter by Expression.
- papsphilip
- 385 posts
alexwheezyhow can i filter based on specific files? i'd like to have a controller where i select the specific files so filter would have to read the filepaths from the controller and keep only those, discard the rest workitems
i have made an attempt here but this has to be automated somehow. maybe python?
- alexwheezy
- 318 posts
Then we can consider 2 more options to solve this problem.
Use Filter by Attribute or Labs Filter by Value, which is actually written in Python Script.
https://www.sidefx.com/docs/houdini/nodes/top/labs--filter_by_value-1.1.html [www.sidefx.com]
- papsphilip
- 385 posts
- alexwheezy
- 318 posts
The File Pattern node knows how to create attributes from a path such as directory, filename, extension.
https://www.sidefx.com/docs/houdini/nodes/top/filepattern.html [www.sidefx.com]
- papsphilip
- 385 posts
- alexwheezy
- 318 posts
Why not use the Labs Filter by Value node itself as a control node? It seems that so far there is no problem to replace it.
All I've changed here is a setting in the asset that allows you to select files on disk rather than populate a line, then you don't have to create a new layer of data indirection and avoid the hassle of writing code.
Edited by alexwheezy - March 24, 2024 01:22:24
- papsphilip
- 385 posts
