hqueue wishlist
   455   0   0
I have been using Hqueue heavily the past two months. As the sole Houdini user in our facility I do my best to maximize our resources. I have two dedicated render clients and my laptop which I develop on. For what it is worth these are the issues I have struggled with. Would be grateful for helpful insights anyone could offer.
#1. Not an HQ issue but I cant use shared folders on our corporate net. I have to resort to manually copying folders to each machine. Is it possible that I could share Teams/Sharepoint or other folders for the client machines?
#2. With some scenes while generating the usd, the machine accumulates memory and tops out and crashes.
- can this job be restarted at the usd generation level? if I reschedule it seem to restart from the beginning clobbering all of the other frames and likely crashing at the same time location.
#3. it would be REALLY helpful to have more relevant info compressed into the main ui. Most if not all of the relevant job and client info should be available from the main screen. ie being able to see and select which machines are working on a job. Which machine is holding the FX or Engine licenses... Switching between the client and job ui are cumbersome and slow as well as not conveying relevant job info.
#4 Licensing. I have an FX license and only recently went to the web license mode which is a HUGE HUGE help. With my current problem from issue #1 I need for each machine to generate its own usd file for Karma rendering but often a machine seems to keep its FX license even though it is only doing the Karma job and I have to manually release it. Ugh. Again the license details would be great to have in the main Ui of Hqueue.
As with most of my Houdini questions I am often humbled by how simple the workflow or solution can be.
Apologies for the long thread. Just looking for workflow suggestions and insights.
JeffMc
Edited by jeffMc - March 31, 2024 21:29:42
