Wedge simulations - one by one (proper way?)
   1014   2   0
Hey gang,
I´m stuck here to figure out what would be the best approach to do this.
Right now I am using a Labs File Cache to wedge the bounds of my sim to run it multiple times since one alone would crash due to ram limits. My goal would be that TOPs is using all available resources (CPU, RAM) and do one sim, empty all cache data (hopefully) and run the next.
Currently I am using a schedule override and locate it to a custom localscheduler which has Limit Jobs set to 1. This seems to work but I wonder if this is the proper way.
Thank you so much!
addition to that:
The CPU usage is heavily limited while jobs are running but not always. The rest of the capacity is booked under "System Idle Process" in the detail task manager.
What is going on here?
If anyone finds this post and is looking for an answer, this did the trick:
the cpu usage spikes seems to be a normal condition.
