Can use Eigen C++ library in Vex or OpenCL?
   1155   6   1
I am now hoping to use the Eigen C++ library in Houdini. I know that I can compile new custom nodes using the HDK, but it can be a bit cumbersome. Since Houdini internally uses the Eigen library, is there a way to use Eigen in Houdini's vex or OpenCL?
use eigen in vex:
HDK: Custom Vex Function [www.sidefx.com]
But it's still inconvenient
You can use it inside Houdini using C++ Wrangle:
This guy integrated the Eigen library also:
https://github.com/lecopivo/cpp-wrangle [github.com]
So you can try that version to access the Eigen library directly. This is the closest you can get albeit not inside VEX or OpenCL.
juejuezi
use eigen in vex:
Thank you very much for your suggestion. I actually have a small problem with HDK. Every time I recompile the plug-in, I have to restart Houdini to recognize it. This is a bit annoying. Is there a way to make Houdini detect custom node updates in real time?
animatrix_
Many thanks for your advice, looks like a very good and interesting solution!
ljzmathematics
juejuezi
use eigen in vex:
The C++ Wrangle SOP won't have this problem. It will only compile if the code is changed or it's run on a new system where it wasn't compiled before or a new version of Houdini that uses a new compiler. The same binaries will be used indefinitely.
SESI did a great job with C++ integration albeit it's not really popularized.
ljzmathematics
juejuezi
use eigen in vex:
As far as I know, there is no way to automatically update. But you can try the C++ Wrangle SOP
