Karma Physical Sky issue
537
2
1
- Masoud
![](https://static.sidefx.com/djangobb_forum/img/authority/vote8.png)
- 411 posts
Hi guys,
I have an issue with the Karma Physical Sky. When I set the "Solar Altitude" below zero:
1)The sky should become "blue", but Karma always shows a warm color(red).
2)The sun should go below the "ground" plane and fade into the dark.
Isn't it a bug?
Thanks for helping.
Karma Sun.png (202.7 KB)
Masoud Saadatmand (MSDVFX)
- jsmack
![](https://static.sidefx.com/djangobb_forum/img/authority/vote10.png)
- 7981 posts
Not a bug, but a limitation. the model is only valid when the sun is at the horizon or above.
- BabaJ
- 2110 posts
It's not a bug or limitation.
It's using the Flat Earth model - so working as intended.
