Getting error in the hairgen node
   487   1   1
Hello. Houdini newbie here.
I'm getting the following error in the haigen node:
Invalid skinprim attribute values found on guide curves.
You can create correct values using a Guide Skin Attrib Lookup SOP.
I've put the Guide Skin Attrib Lookup node but still get the same error. I'd have attached my work file but no matter how much I compress it still exceeds the upload limit. So here is the link if anyone wants to open and check it:
https://mega.nz/file/gWUn3ayb#ldbesQzxncUn-KrcpsvlSvKc2Eo_YHpDmmJtHX6fr1E [mega.nz]
Any help is appreciated. Thanks!!
you might need to recreate the values, check fabio hair system, they do that in their network, to assist if some one brings curves from other software,
