Heightfield filecache
   450   1   1
Hello, doing a tutorial on heightfields (which is a houdini 18 tutorial) but im working in houdini 20
the tutorial is going over conversion and export of the heightfield as an obj
it is using a fileCache node to do so, however
when I put one of these down in houdini 20 everything is changed and the tabs are different and there is no option for exporting as obj
houdini 18 filecache image and 20 filecache image are attached
Passion for what you do and a friendly smile go a long way.
The interface of File Cache node has changed since Houdini 19.0, by default it acts in a way where you focus on folder path and file baseneme, then it constructs the full file path for you.
To have more control on the file path, you can change "File Path" parameter from "Constructed" to "Explicit", and write a filename with .obj extension.
Edited by ObeidaZakzak - April 24, 2024 14:09:14
