Hello guys, i'm having trouble figuring out how to work with fonts in houdini fortypography animation.
I was wondering how to achieve this result within houdini?
I figured out basic font topology preperation with a help of tutorial on twisting text on youtube, but effect works on everything as a whole geometry where i want to control each letter and affect it specifically.
Can someone share their thoughts on this, i'm kind of stuck here.
I also have free mops if that's helpfull in any way.
Just to be clear i don't want to twist it instead i want to replicate text animation from this tutorial (https://www.youtube.com/watch?v=53MikIaOJGQ&t=983s&ab_channel=Allixar)
How to do typography animation?
972 3 2- woltiel
- 13 posts
- Enivob
- 2625 posts
I played around with emulating some After Effects typography. Feel free to check out the thread on OdForce.
https://forums.odforce.net/topic/49794-after-effects-text-styles/ [forums.odforce.net]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- cdordelly
- 162 posts
Hi!
You can also take a look to the MOPs Plus Typography node:
https://www.youtube.com/watch?v=lJ907xySsog [www.youtube.com]
It offers a very similar experience to the Mograph Text object from C4D because it packs the letters so you can use other MOPs or nodes to edit the packed geometry.
MOPs: https://www.motionoperators.com [www.motionoperators.com]
MOPsPlus: https://www.motionoperators.com/info/mopsplus/ [www.motionoperators.com]
To use the MOPs+ Typography node you will need to buy the commercial extension from MOPs, I always recommend to consider buy it to because it has a ton of useful nodes to improve multiple kind of workflows,
I made a quick demo showing this, I didn't see the complete tutorial reference but I guess it works to share an idea about this:
Hope that helps,
Cheers!
Hope that helps,
Cheers!
- woltiel
- 13 posts
EnivobThis is great, also huge shoutout to your community activity on forums, there was quite a number of times i googled question and found answer in your replies or threads you partaked on odforce or here.
It's nice to know that ae JS script can be interpreted on vex language
