Greeting to everybody
Ambient occlusion is a standard for almoust all 3d-editords and all 3d-engines - and after it the developers ignore this tast to be realised in karma?
There is a thought that is well known: - "beauty requires sacrifice". Why developers don't take things into account
The main shader should have a slot for ambient oclusion even if it is a physically correct visualizer
Is there new easy colution for it?
1491 9 4- Staglaitor
- 43 posts
- Enivob
- 2625 posts
- Staglaitor
- 43 posts
Enivob
https://www.sidefx.com/forum/topic/82304/?page=1#post-353914 [www.sidefx.com]
Yes! What if I need to get a contact shadow effect????
- Staglaitor
- 43 posts
Enivob
That method you game me in a link has relation to generative AO but i already have AO made in substance painter
I just need to set in into Ao slot
Edited by Staglaitor - May 23, 2024 08:47:17
- Enivob
- 2625 posts
- antc
- 331 posts
StaglaitorJust add mtlxambientocclusion (or you're painted texture) to both shaders. The raytracing mtlxambientocclusion does is global, so you will automatically get a contact shadow type effect between objects.
Edited by antc - May 23, 2024 14:52:04
- Fordencore1966
- 11 posts
antc
About mtlxambientocclusion node
The developers make show of any new features in update or in new version of houdini OR the developers secretly release certain tools and it is your problem to find these tools. I've searched for them myself - I didn't find anything (i have no 20th version of houdini)
Edited by Fordencore1966 - May 24, 2024 10:57:14
- antc
- 331 posts
StaglaitorThe decision would be up to the MaterialX folks to add to the specification [materialx.org], not SideFX devs. A dedicated slot sounds unlikely to me though because of the many ways something non physical like occlusion could be utilized. Typically it gets used to darken the base color a bit which is super easy to do either way.
Edited by antc - May 26, 2024 15:37:48
- Fordencore1966
- 11 posts
antc
That would be up to the materialx folks to add to the specification
As I understand it, sidefx implements a separate responsibility and all the material preparation work should be done by the MaterialX organization?
sorry - i don't know english and sometimes i am forced to guess
Edited by Fordencore1966 - May 25, 2024 13:58:05
- antc
- 331 posts
Fordencore1966
Right, MaterialX is a specification, not an implementation. SideFX are following the specification, which states ambient occlusion should be supported via mtlxambientocclusion.
Edited by antc - May 26, 2024 16:04:57
