Hello!
Is there an approach that yields correctly anti-aliased renders for Alpha values lower than 1 from the OpenGL rop?
I've animated the point attribute 'Alpha' on a piece of geometry from 0 to 1 over time. When the value is 1, the antialiasing in the render is correct. Any lower value presents aliased, jagged edges in the C and Alpha channels. I have tried the following:
- increasing AA in display options in the openGL ROP
- set Antialiasing - Transparency in the Nvidia Control Panel to 8x
- tried rendering in Mantra which solves the issue but takes a very long time
- tried with and without a principled shader assigned to the geometry
Thanks very much,
Ryan
Aliased Alpha in OpenGL render
759 4 0- subsampler
- 3 posts
- Enivob
- 2617 posts
- malexander
- 5199 posts
- subsampler
- 3 posts
- Enivob
- 2617 posts
