Attribute transfer node does not transfer normals
763 3 2-
- Chri_stoph_1
- 2 posts
I am currently following a tutorial “Houdini isn't scary” which is about replacing a scatter node with a DOP system via a switch node. The problem is that the “attribute transfer” node does not transfer the normals of the geometry to the DOP system. i have actually followed the steps in the tutorial exactly.
- Tanto
- 442 posts
- Chri_stoph_1
- 2 posts
- Tanto
- 442 posts
Sorry, hadn't noticed the file.
So first you're deleting the whole geometry on the left branch, so there's nothing to copy normals from. I disabled the Delete sop.
Then, in your Normals sop, add you normals to your points insted of your vertices.
Finally, you have to actually specify the attribute you want to transfer in your Attribute Transfer node, so enter N in the points list.
Should work.
Should work.
