I need a bit of insight if possible.
I was playing a bit with layout node. Got small asset library of misc trees, and created small forest with layout node. But now I would like to go in and edit a bit, scale, density.. but I have no idea how to do that!!
Even if I use place option and have 1 tree or asset, having to go in later and change, orientation scale all is a bit of miss and hit. Is there proper workflow how to edit layout node assets later on?
Editing layout node
617 4 2- Mirko Jankovic
- 149 posts
- mtucker
- 4493 posts
- Mirko Jankovic
- 149 posts
I mean yea those can affect assets, but sometimes they just don;t Honestly for me is more of an trial and error.
So those I mange to use from time to time, but for example, have bunch off trees painted with fill, draw area and filled. Now I could not figure out a way to change density for that area for example.
- Mirko Jankovic
- 149 posts
https://www.youtube.com/watch?v=4wafUOzROPw&ab_channel=AdrienLambert [www.youtube.com]
This! This is big problem I run out and found this again after looking fro solution.
Scaling from fill in layout is messed up and still not fixed.
Pleas do check this around 9 min 40 sec. This is also big issue
- wanglifu
- 182 posts
