Unity Plug-in not visible in installation options
   2873   7   2
I want to install Houdini with the Unity Plug-in but this one is not visible in the options before installation.
Same after the installation in the Engine Plug-in part where I can install all other plug-in (Maya, Unreal and 3DS) but no Unity plug-in in sight.
The Houdini Engine for Unity/unreal license is installed though.
I don't know why. I just follow the instruction for the installation of this plugin (here [www.sidefx.com]) : "Once you have downloaded the Houdini installer, run it and be sure to select the "Houdini Engine for Unity" option on the Houdini Engine installer screen."
Can you help me on this?
Thanks.
Installed licenses.jpg (118.3 KB)
Unfortunately, that is expected - as we're currently having issues with our Unity licenses.
Because of this - we were forced to remove the Unity plugin from the installer/launcher temporarily as we can no longer build the Unity plugin.
We've been in touch with Unity about this issue for a few weeks already - this seems to have been caused by a problem with their licensing system.
They finally found the problem and a solution for it, so hopefully, we'll be able to build the Unity plugin again in the coming days.
Our previous production build, H20.0.688 was the last build that still had the Unity plugin.
I'll be sure to post here once the plugin's back in the installer/launcher.
Sorry for the inconvenience.
dpernuit
Thank you for this answer.
Unity has been a mess lately so I'm not surprised by this kind of outcome.
I'm just good at beginning something in the most awkward moment. ^^
I hope it will be back soon.
Edited by rnst1 - June 5, 2024 03:42:14
dpernuit
Thank you for the update on this, I was wondering where it had gone when I updated to the latest Houdini production build.
Quick update on this, as of today's build (H20.0.736), the Unity plugin is finally back in the installer.
Sorry it took so long, but unfortunately, the issue wasn't on our end, so there wasn't much we could do to speed this up.
Glad you got it sorted. Any eta on H20.0.736 reaching production build?
I am trying to install the houdini engine for unity but I can't find the folder with the unity package.
I have the steam version of houdini indie.
What can I do?
Edited by gabhpe - June 24, 2024 06:24:13
As mentioned above, that is expected, we had some issues with unity licenses which forced to us to remove the unity plugin from the last production build. Unity finally found a solution to the issue, so the plugin is back in current H20 daily builds.
For steam, you could either switch to the daily20.0 or previous production build branch, as these both have the plugin.
I'd recommend switching to the previous production build (in properties > beta branch, choose the previous 20.0 production build).
When we release the next production build, you can then return to the default H20 branch - as the next prod build will have the unity plugin.
