Hello all,
Is there an event callback for when the frame changes when caching/saving to disk (Pre-Frame)?
I know of the "Pre-Frame" script which executes before each frame is cached, however is there a way to hook in to any "Pre Render" event in the Houdini session so that I don't need to set a "Pre Frame" script on every ROP?
Any ideas welcome, thank you
Pre-Frame Event Callback - Does this exist in some form?
556 3 0-
- AdamChabane
- 20 posts
- Enivob
- 2607 posts
- AdamChabane
- 20 posts
- graham
- 1920 posts
Unfortunately having global scripts for these render events is a long requested feature.
At this point the "best" you can do it is to use a ROP render callback (hou.RopNode.addRenderEventCallback()). They will work, however you're left with the tediousness of attaching your callback functions to all ROP nodes on hip file load, or on node creation
![](/static/djangobb_forum/img/smilies/sad.png)
