Path to second output of a node?
   Views 759   Replies 3   Subscribers 1
Lets say I have a node with more outputs:
/obj/geo/vellumsolver
Isn't there an "universal" syntax to reference the second output? For example to Object Merge SOP the Constraint geometry?
/obj/geo/vellumsolver:2?
Do I have to know the exact name of the internal Output node?
/obj/geo/vellumsolver/output2
This expression function kind of works, but there need to be nodes connected to the referenced node ("outside"). And the indexing counts only the connected nodes:
`opoutputpath("/obj/geo/vellumsolver", 1)`
In the attached image, the index 1 is the node "B"
I asked for this a few years ago and SESI told me this is not possible. It would be very useful to have this indeed. I was also thinking it would work like you imagined:
Though I would assume to start from 0 for the first input.
Thank you very much! So I'm calm that I didn't miss or overlook anything.
