APEX smoothik issue
1293 7 3- lorsange
- 8 posts
Hello. First of all, I want to thank Max Rose and CGI Nerd for the APEX tutorials and Bogdan Lazar for the inspiration. I encountered a problem when using APEX Autorig Component in smootnik mode on legs - when activated, the character’s legs turn inward (works well with hands btw). I see that the joints change the transform, but I can't figure out how to avoid it. Changing the skeleton transforms does not help solve the problem.
Before LegIK:
After LegIK:
Please, if someone can explain how to avoid this error, I will be grateful
Before LegIK:
After LegIK:
Edited by lorsange - June 23, 2024 01:25:15
- edward
- 7871 posts
- lorsange
- 8 posts
- william_harley
- 69 posts
lorsangeHi, so there are a couple of things that needed to be addressed. The most important is the orientation of the joints, In your example I have reverted the skeleton to the original orientations, this seems to work.edward
Offhand, it's pretty hard to tell from images alone, could you post your hip file?
Sure, sorryImage Not Found
Second, You will need a slight bend in the knee in order for the ik solver to set an initial direction of the bend, if you are using a completely straight leg it will result in the leg possibly facing backwards.
Another thing to note, is that if you want to add joints to the guides to make sure that their transform attribs are set up.
Hope this helps
Edited by william_harley - June 24, 2024 14:46:46
- lorsange
- 8 posts
william_harleyFeel myself total idiot, such a dumb mistake i totally forgot.
Thank You so much for help.
- lorsange
- 8 posts
- esttri
- 83 posts
- chovasie
- 2 posts
