How to search for a shelf tool?
   Views 639   Replies 4   Subscribers 0
For example, I've noticed that since H20, Quad Remesh SOP has a shelf tool:
radialmenu.runShelfTool(kwargs, 'sop_quadremesh')
But I can't find which shelf it is located. Is there a way to to search for a specific shelf tool?
Edited by raincole - June 25, 2024 08:03:43
Basic module for working with shelves.
https://www.sidefx.com/docs/houdini/hom/hou/shelves.html [www.sidefx.com]
hou.shelves.tool("sop_quadremesh").filePath()
hou.shelves.tool("sop_quadremesh").toolMenuLocations()
But it's a contextual tool, you won't find it on the shelf.
alexwheezy
Thank you for the answer. That being said, I'm still not sure what "contextual tool" is... what's the difference between a contextual tool and a shelf tool? Can I create a contextual tool or it's hardcoded in Houdini?
raincole
alexwheezy
SOP_Qauadremesh is indeed defined in SopStateTool.shelf, but that doesn't mean you can create this shelf directly. As you can see this shelf uses the state viewer for activation.
You can borrow a piece of code for your shelf to have similar functionality.
<tool name="sop_quadremesh" label="Quad Remesh (Beta)" icon="SOP_quadremesh">
<helpURL>operator:Sop/quadremesh</helpURL>
<toolMenuContext name="viewer">
<contextNetType>SOP</contextNetType>
</toolMenuContext>
<toolMenuContext name="network">
<contextOpType>Sop/quadremesh</contextOpType>
</toolMenuContext>
<toolSubmenu>Geometry/Polygons</toolSubmenu>
<toolSubmenu>Geometry/Polygons/Topology</toolSubmenu>
<script scriptType="python"><![CDATA[import soptoolutils
soptoolutils.customStateTool(kwargs, 'quadremesh')]]></script>
</tool>
import soptooltuils
I see. Never realize there is that special kind of shelf. Thank for the explanation.
