With all the great changes in H20.5, I’m wondering when would one still consider using SOP content?
Why not just build for example your scene straight in Solaris and use SOP Create to create everything you need.
Are there any specific limitations around this approach?
I’m assuming that SOPs/OBJ are still in houdini native scene format and Solaris is USD and hence there’s some constant translation happening? And maybe along those lines - why couldn’t’ houdini go all USD native?
H20.5 - can we just ditch OBJ?
1549 11 5-
- LukeP
- 246 posts
- alexwheezy
- 223 posts
- BabaJ
- 2056 posts
LukeP
Because it's easier to use Obj/Sop context for building, designing and organizing projects.(speaking for myself).
Why take the extra steps and do that in Solaris? When you are not going to use Solaris?
alexwheezyIt's for forward 'compatability', because it serves as a useful context.
It's backwards compatibility.
Edited by BabaJ - June 29, 2024 08:00:00
- Jonathan de Blok
- 265 posts
USD is more an assembly/lookdev/playback thing, it not something you can comfortably create content in as it doesn't do skinning, deformations, simulations etc. And /obj is just a 100x faster for a lot of things, so while they do have some overlap neither is a replacement for the other.
More code, less clicks.
- vinyvince
- 256 posts
LukeP
USD does not tick the need of all of us, and to build a complex massive full openworld and shot/asset pipeline of over 120 HDA where a single one could be over 600 nodes with tons of Python and other DCCs and engineers code outside houdini is a huge thing than many, many of us are not interested or just can not justify the move and resources for at the moment.
Many, including me are still looking for a better viewport optimization like what Clarisse was offering without having to deal with all USD complications, and so far my experience with Karma hasn't been quite satisfying and is still way behind in term of reactivity thing like Eeve, Redshift, or to the glorious quality of Octane... Maybe im wrong, im not closed to change my mind.
But H20.5 has brought a lot's of hope, many things i haven't waiting for like many of us, are happening to what it looks to becomee one of the most exiting milestone in the stunning history of Houdini development!
Edited by vinyvince - June 29, 2024 12:52:25
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- GCharb
- 256 posts
- antc
- 291 posts
vinyvince
That’s totally fair enough, but if not HDAs or USD I’m genuinely curious how folks are sharing stuff between shots or setups or whatever in Houdini. Back when I was at a small studio that used Maya exclusively and often worked projects with a handful of shots, we still had to deal with referencing and versioning assets and all that kind thing.
- Soothsayer
- 868 posts
- WinterLightDP
- 5 posts
I'm getting used to using the build context to create, and then light and render it in Solaris. It's easier, and also keeps the Solaris part of things relatively simple and streamlined.
Not that I'm an expert with Houdini or anything yet, I'm still learning
http://WinterLightStudios.ca [winterlightstudios.ca]
- keyframe
- 1533 posts
- tamte
- 8667 posts
On top of LOP context not being ready to replace Object context yet, there is also no need to push this possible future replacement to happen, it will happen naturally once it is ready, faster and more convenient to use LOPs in all areas
It will also most likely happen independently for each artist at different times or never, you can always use whichever contexts fit your workflows better
Edited by tamte - July 4, 2024 15:42:56
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- MASee
- 4 posts
关键帧While I don't agree that Solaris is more complex for lookdev, it is actually very user-friendly. The only issue is the current lack of USD model resources, which is a long-term development plan. The only reason I hesitate to use it is due to performance concerns. The Hydra framework seems to significantly affect rendering performance and real-time capabilities. I've tested rendering the same model and HDR lighting with Redshift, RenderMan, and V-Ray, and the response and rendering speed at the OBJ level always outperform Solaris. I believe this is an issue with USD. Pixar's development is always very slow, which makes it quite awkward for SideFX as well.
FWIW, I've never set foot in the /stage context for production work.
I still can't wrap my head around the upside for small commercial projects and tiny (sometimes solo) teams.
The extra complexity appears to offer nothing in return in my scenario
G
