For each work item I render a flipbook using a Python Script.
For each work item I would like to swap geometry in a File SOP using `@pdg_index` to alter the filepath.
When I try this, the PDG attributes don't work during the cook. But when I press on the little dots, now everything starts working. But of course if I recook, it will stop working again.
How can I solve this?
I'm attaching a small test scene showcasing my issue if that helps.
EDIT: I just figured out a workaround, which is to set the parameters using that Python Script itself. It's not very scalable, but at least it works.
How to make PDG attributes work with Flipbooks?
688 2 1- alexmajewski
- 38 posts
- alexwheezy
- 318 posts
- alexmajewski
- 38 posts
