TOPs trying to rename UDIM to add ACEScg into file name
   Views 548   Replies 2   Subscribers 1
Hi.
I am trying to make a tool for converting images to ACEScg.
During the conversion I want to rename the file. This is where I am having an issue. For example:
albedo.1001.exr
to
albedo.ACEScg.1001.exr
I think I need to create an attribute from string, split it and somehow put it back together again feeding that into the openimageio output path.
Has anyone managed to do this sort of thing before?. Best. Mark
ACEScg_conversion.hipnc (131.7 KB)
albedo.1001.exr (61.6 KB)
albedo.1002.exr (61.6 KB)
You can use a dot delimiter and then use an array of values to substitute in the paths.
ACEScg_conversion_fix.hipnc (136.3 KB)
Hi. Wow. thanks for that super quick help!
Best
