I've just started using Hodini20 and try to use Houdini Ocean Procedural node.
I had Large Ocean setup with Karma Ocean node in Houdini 19.5 and the large grid size is 500000x500000 and it worked fine.
I tried to use the same setup for Houdini Ocean Procedural node in Houdini 20 and try to render in Karma..While "/expand_procedural ---> TriDivide" process is going, RAM is going over 128GB and process was stopped..
I tried to reduced resolution exponent, Dice quality, downsampling.. I still got the same issue..
If anyone could suggest what I missed, I would be great..
Thanks in advance.
RAM usage issue for Houdini Ocean Procedural with Karma
573 0 0-
- tmaeda777
- 1 posts
