Hi, I've a problem sending a usd render to deadline in TOP.
It's working with no problems in H19.5 and H20, but in H20.5 it seems that the scheduler is not reading the remote connection server
When I try to cook the node, I get this error from the scheduler
Deadline SubmitJob error: Error: Could not retrieve NetworkRoot from "Thinkbox\Deadline10\deadline.ini" because it does not exist.
From the deadline documentation [docs.thinkboxsoftware.com] you need the specify a NetworkRoot only if your ConnectionType parameter is set to Direct, but in my deadline.ini is set to Remote...
I've tried to override the type of connection in the deadline scheduler node, but I got this error
Ignoring Deadline command non-json result: b'Error: Encountered the following error when trying to load the specified certificate: Cannot find the requested object. (System.ApplicationException)\r\n'
Any suggestions? thanks
Fabio
Deadline scheduler H20.5
2152 8 4- bflow
- 3 posts
- CoreSign
- 29 posts
I submitted as a bug ,and get reply:
Please try enabling "inherit local environment".
This behavior change is noted in the H20.5 What's New documentation (https://www.sidefx.com/docs/houdini/news/20_5/pdg.html):
The Houdini 20.5 Deadline Scheduler now submits one job per work item as opposed to Houdini 20.0 where the Deadline Scheduler submitted one task per work item.
Fix the problem.
Fix the problem.
- bflow
- 3 posts
- CoreSign
- 29 posts
- changehpx
- 6 posts
- bflow
- 3 posts
- changehpx
- 6 posts
- xyzDist
- 10 posts
- AhmedHindy
- 136 posts
