ffmpeg log debug
   Views 726   Replies 3   Subscribers 1
I have an issue with ffmpeg, it works if I just run it with a command line in the terminal but fails in houdini top's
Where can I look up the log of what is going on?
Thank you
Edited by Ivan L - July 19, 2024 13:02:13
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
The operation log is stored directly in the work item after cooking. You can click on the work item to view it.
sometimes all it shows is this
Ivan L
You will not see a task logging run for the In Process cooking type.
