Ropfetch not caching properly when using "out of process"
   Views 530   Replies 0   Subscribers 0
Hello, I am following Applied Houdini's Rigids II v2 course and am now in the TOPs section. When I try to cache the ropfetch node and its cook type is set to "out of process", it only manages to cache 6 frames in total before the rest fail. I think this is a problem with the output of the node since when I look at the node's info, the output shown there is incorrect and doesn't match the rop's output path. However, I am not sure why exactly this happens because if I switch the cook type to "in process", the ropfetch caches properly. I have embedded the hip file here if anyone wants to have a look, any help would be greatly appreciated!
RigidsIIv2.issue.hipnc (1.9 MB)
