TOPs Partition with random index
   Views 797   Replies 4   Subscribers 1
Let's say I have two nodes, one with 5 work items (A B C D E) and another with 3 work items (A B C), how do I partition the work items of my first node with random indexes of work items from the second node? I can do a Partition by Attribute, but how would I find the maximum number of work items in the 2nd node from within the first node's pipe?
I think you can get a similar randomization pattern with Partition by Combination.
alexwheezy
Hmmm I tried that, however it does not always match partitions between the two nodes. Also the partitioning is very linear, and not random.
Partition by comparison can do this, a bit cumbersome to setup if you don't know the work item counts up front. But seems to work well enough
partition_random-select-pair.hip (234.7 KB)
tyler.britton
alexwheezy
You could try using a Python Partitioner with a custom index that will have a random value for other items.
partition_by_custom_index.hipnc (156.8 KB)
