In 20.5 some windows don't appear to be affected by the "Global UI Scale" or "Icon Size and Layout" preferences.
Specifically the popup view when middle clicking on a node and also the help documentation. We can use cmd + and cmd - to increase/decrease the font size but it goes away each restart.
Is there a way to persist the larger fonts?
High DPI settings
1444 13 1- GoCeltics
- 13 posts
- danry
- 7 posts
- RGaal
- 143 posts
- johnmather
- 529 posts
- mchaput
- 503 posts
The node info window and help pane are both scaled by the global UI scale. If it doesn't seem to be working for you, please file a bug and explain what you're doing, what you're seeing, and what you'd expect to see. Note that you have to restart Houdini for a new UI scale to take effect.
Persisting the zoom level is on the to do list
- GoCeltics
- 13 posts
- mchaput
- 503 posts
- GoCeltics
- 13 posts
How to see fix? Daily build download links don't seem to show date:
https://www.sidefx.com/download/daily-builds/?mac=true [www.sidefx.com]
- mchaput
- 503 posts
Here's what I did:
So it seems to work for me. If it's not working for you, please file a bug with steps to reproduce the problem.
- Downloaded 20.5.327 for Mac.
- Started Houdini, opened General User Interface prefs, changed Global UI Scale from 2 to 3.
- Quit Houdini and restarted it so the scale pref would take effect.
- Put down a node and showed the node info window for it. The contents of the info window were 1.5x bigger.
- GoCeltics
- 13 posts
This worked for some nodes (e.g. geometry nodes) and looks so much better!
Some nodes use a different UI element than the rest. For example a pyro solver or smoke object don't have the "new style" info menus and don't take UI scale into account. These can't be increased with cmd + either. Are these using QT and is there an environment variable that can change the scaling? No luck from our end on this so far. The reason this matters is because on high resolution (4k or more) monitors it is quite tough to read these popups at all.
The help also doesn't seem to use UI scale, but we can still use cmd + to increase size.
Edited by GoCeltics - Aug. 15, 2024 16:44:46
- GoCeltics
- 13 posts
- mchaput
- 503 posts
- GoCeltics
- 13 posts
- GoCeltics
- 13 posts
If anyone else has this issue on MacOS... as a temporary workaround it is possible to open help in Safari http://127.0.0.1:57753/ [127.0.0.1]
Font and links work like you would want
