Hello
I'm struggling with the New Rig Car Follow path SOP. There's a strange behavior on the steering wheels at the end of the animation that I cannot remove. I tried resampling, smoothing, etc and there's always a wonky rotation in the end... What might be causing that?
H20.5 RBD Car Rig - Follow Path
938 4 2- Jose Molfino
- 19 posts
- Jose Molfino
- 19 posts
- npetit
- 413 posts
Hi Jose,
Do you have a hip file you could share for me to look at? I can't seem to repro the wonky rotation issue.
For the dynamic springs, they affect the car body after which another pass of wheel/ground collisions is applied - this is to ensure they don't penetrate the ground as the body gets re-oriented.
- Jose Molfino
- 19 posts
Hi Nick
Thanks for your response. Let me mention the asset you guys put together is aweomse!
Sure, see attached the hip file.
Sorry I didn't get what you mean about collision passes. If I turn "Dynamic Springs" toggle ON, the entire car woobles with the wheels also... am I missing something?
Edited by Jose Molfino - Aug. 20, 2024 08:32:15
- npetit
- 413 posts
