Hi - any tips on keeping MPM solver from messing up collisions? I've got some viscous/sticky fluids inside a sealed collider, using the vdb/invert option in the MPM collider node. The simulation always has leaks/errors, it looks like the sim is lagging the animation and this allows the edge particles to escape. See vid attached
Things I've tried:
1. substeps - min/max up to 200/20000
2. CFL - down to 0.01
3. looser/denser meshing for the collider
4. changing collision type to animated deforming (instead of animated/rigid)
Thanks for any advice! Chris
Leaking MPM solver
461 2 0- ChrisCousins
- 16 posts
- ChrisCousins
- 16 posts
- BabaJ
- 2110 posts
Can't remember the issue I had, but was puzzled as to how to change it when I was doing some metal mpm sims.
Putting this setting on helped a lot and gave a much better result.
The only difference in my case, being metal, it worked better with the drop down set to 'Position-Based Move Outside Colliders'
