New to Redshift with Houdini – Need Help with OCIO Error
   913   1   1
Hi everyone,
I'm new to using Redshift with Houdini, and I've run into an issue I can't seem to resolve. Every time I try to view render using Redshift the Redshift_ROP1 node throws the following error:
OpenColorIO failed loading or validating file:
C:\Users\Admin\Documents\houdini20.5\ocio\houdini-config-v2.1.0_aces-v1.3_ocio-v2.3.ocio
I've tried troubleshooting, but nothing seems to work. If anyone has encountered this before or has any suggestions on how to fix it, I’d really appreciate the help!
Thanks in advance!
Hi!
RS 3.6.04- doesn't support OCIO 2.3, Houdini 20.5 has OCIO 2.3 by default, the upcoming version of RS will support OCIO 2.3, in the meantime, you can point to another OCIO config with the $OCIO system variable, you can use the .ocio config that comes with Redshift.
