custom attribute available at DOP level
   344   0   0
Hey guys. I have a RBD sim which I want to control when constraints are generated with a custom attribute created inside a sopsolver. Problem is that when I leave the sopsolver and go back to DOP level, the a swtich I'm using to direct the stream says "local variable not recognized". I want to use the varibale DIST to trigger the creation of the constraints. So the question is how can I create a custom variable inside a sopsolver and make it available in the DOP level (one level above)? Thanks.
Edited by nelpiper73 - Sept. 6, 2024 13:17:46
destruction.hiplc (231.0 KB)
