10928: Fatal error: Segmentation fault
   812   1   1
Hi, I am facing this problem while working with cloud.
10928: Fatal error: Segmentation error
Application data saved to C:/Users/cvsli/AppData/Local/Temp/houdini_temp/crash.a_sky_plane_24.cvsli_10928.hip
The crash log is saved in C:/Users/cvsli/AppData/Local/Temp/houdini_temp/crash.a_sky_plane_24.cvsli_10928_log.txt.
7752: Fatal error: Segmentation error
Saving application data to C:/Users/cvsli/AppData/Local/Temp/houdini_temp/crash.a_sky_plane_24.cvsli_7752.hip
23760: Fatal error: Segmentation error
Application data saved to C:/Users/cvsli/AppData/Local/Temp/houdini_temp/crash.a_sky_plane_26.cvsli_23760.hip
The crash log is saved in C:/Users/cvsli/AppData/Local/Temp/houdini_temp/crash.a_sky_plane_26.cvsli_23760_log.txt
I have run into this problem with clouds. When I start moving the cloud I want, I get this error. I don't understand what it is related to. Also these errors occur when moving the camera. What to do? Maybe who has faced with this problem?
By the way, this error is only in version 20.5.278. In version 20.0.625 everything works perfectly!!!!!
System:
NVIDIA System Report created: 09/08/2024 13:01:21
NVIDIA application version: 10.0.2.210
Operating system: ���������� Windows 11 ��������, Version 10.0.22631
DirectX Runtime Environment Version: DirectX 12
Driver: Driver Studio - 560.81 - Aug 6, 2024
CPU: 12th Gen Intel(R) Core(TM) i7-12700K
RAM: 128.0 GB
Storage (4): HDD - 931.5 GB,SSD - 1.8 TB,+ 2 more
Video card
GPU: NVIDIA GeForce RTX 3070 Ti
Direct3D capability level: 12_1
CUDA cores: 6144
Graphics clock speed: 1770 MHz
Resizable panel: None
Memory Transfer Rate: 19.00 Gbps
Memory Interface: 256 bits
Memory bandwidth: 608.064 GB/sec.
Available graphics memory: 73613 MB
Dedicated video memory: 8192 MB GDDR6X
System video memory: 0 MB
Total system memory: 65421 MB
Video BIOS Version: 94.04.5a.00.1f
IRQ: Not used
Bus: PCI Express x16 Gen2
Device ID: 10DE 2482 138C196E
Part number: G141 0010
Display (1): LG Electronics LG ULTRAGEAR.
Resolution: 2560 x 1440 (native)
Refresh rate: 144 Hz
Desktop Colour Depth: Max (32 bit)
Display Technology: G-SYNC Support
HDCP: Supported
Edited by drouviii - Sept. 8, 2024 10:09:12
What's in the crash log txt file?
