Align the viewport camera to a selected polygon?
297 2 1- RGaal
- 133 posts
- PolyMarvels
- 911 posts
Yes, you can...but you need to use Construction Plane.
1. Set CP to a polygon or set of polygons you want to be in a frame.
2. While CP active, in viewport top right corner click on Persp menu
3. Scroll down to Home and select 'C-Plane Normal'
4. Select desired Camera and lock it
5. In viewport click 'Spacebar + H'
6. DONE
Basically, Camera view will align with CP normal. Hope that helps!
6. DONE
QA Specialist at Greyscalegorilla |PolyMarvels YT: https://www.youtube.com/channel/UCqXuTLiaL-jqvn3LK1XlwHg [www.youtube.com] | Instagram: https://www.instagram.com/polymarvels/?hl=en [www.instagram.com]
- erichocean
- 8 posts
