When I activate " display points" and I'm at Object level, Houdini shows me all the points in the scene, no matter what I have selected, and the viewport turns into a blue sea with a lot of high rez objects.
When I then enter a Geo node to edit an object at SOP level, still all the points are visible when "Show All Objects" is active or I'm editing points.
When I then toggle "Display Points" suddenly only the points of the object I'm editing are visible. But I can't seem to find a way to hide the points of background object when "Show All Objects" is active and I'm editing points.
Is there a way to at least automate hiding points when Display Points is active, so one doesn't have to toggle manually all the time ?
And maybe there's even a way to only show the points of the currently selected Geo at Object level or SOP level when editing points ? But I suspect that would be bit too advanced for the Houdini viewport ;-)
I've been searching, but no luck so far, anyone ?
H 20.0.751
Display Points in the viewport
498 0 1-
- toonafish
- 506 posts
