HDA default parameter not update in different hips
   336   0   0
If I changed a HDA parameter's default value, all instances parameter with default value in current scene will be updated to the new one.
But when I open another hip that has same instance, it does not update to the new default value.
This will cause some problems. Because default value means default behavior. In this case the instance nodes become non-default behavior when HDA changed.
Is it a bug?
Thanks.
Edited by jerry7 - Sept. 9, 2024 18:31:21
